Subject: Re: Super Kemvar
Super Kemvar
9/18/19
Al
I have never used Kemvar. It is pigmented and color is Latte. Customer says it’s called Super Kemvar. I checked SW spec sheet and I just find Kemvar not Super Kemvar. Spec sheet says pigmented Kemvar gets reduced 16 percent per gallon.
Any info appreciated,
Al
9/19/19       #2: Super Kemvar ...
DannyB Member
https://www.paintdocs.com/docs/webPDF.jsp?SITEID=SWOEM&lang=E&doctype=PDS&
amp;prodno=T77F47
and
pe=PDS&prodno=T77F4
hopefully help
9/20/19       #3: Super Kemvar ...
Al
Thank you Danny I had seen that spec sheet. I think super Kemvar is clear and the pigmented is called something else. I am matching existing cabinets and customer is to supply the finish from original cabinet manufacture. For some reason they won’t give me the model number of finish. Thanks
9/20/19       #4: Super Kemvar ...
DannyB
Yeah, so as you suspect, they have never made a pigmented called super kemvar, only kemvar plus.
The only interesting idea I can think of other than "they are just wrong" is that the color is deep enough that it needs a clear base, and so they actually did use super kemvar.
9/21/19       #5: Super Kemvar ...
Shane
The formula string H66XXW%^&* the facility used to match will tell you exactly which product it is..... post it up and ill see If I can look it up for you
