Subject: Re: finishing
finishing
10/21/19
thomas iapicco
best table top finish for resturants
10/22/19       #2: finishing ...
Shane
polyester over new construction.... period.. Refinish? Walk away and find more work as the customer will not be happy and you'll blow more time and material than you ever think you planned for...
10/22/19       #3: finishing ...
Bob Niemeyer
New work polyester basecoats, PU topcoats.
Refinish and we do lots of it, PU system. But not all PU's are created equal. Search out the tough ones for this market.
10/22/19       #4: finishing ...
Bob, don't you have bonding issues with all the grease and sanitizing liquids used by restaurant staff and cleaning crews? Can't even imagine what's on the bottom surface!
10/22/19       #5: finishing ...
Bob Niemeyer  Member
Never had an adhesion issue. We chemical strip and then machine sand. Use PU compatible stains and then start with the finishing system. I always like to use the proper Isolante for the job first and then the proper sealer and topcoat. Sometimes we will have a fisheye issue due to somebody using a silicone based polish but that is easy to deal with using the proper additives.
I use ICA finish as they have many options in sealers and topcoats that provide very hi chemical, scratch and marr resistance but yet are flexible enough to dent without chipping.
The worst part of the job is whats wiped on the underside of the tables !! Sometimes that is just plain nasty.
