Subject: Re: Two-tone wood stain
Two-tone wood stain
10/25/19
Tony TerBorg Member
I want to recreate the type of finish that is on the image of the picture frame I have attached. This is for a benchtop. Sorry for the quality of the image but as you can see it appears to have a mahogony tone as the primary stain color but at the edges it deepens to a jacobean looking color. I am wondering how this was done and if someone with experience can detail or point me to a tutorial on how to achieve this look. Thanks in advance.
View higher quality, full size image (1500 X 2000)
10/25/19       #2: Two-tone wood stain ...
Looks like a sand-thru. Stain it brown. Paint it black. Sand thru the black until you see the proper amount of wood. Clear coat it when you are content.
10/25/19       #3: Two-tone wood stain ...
Bob Niemeyer
Website: http://niemeyerrestoration.com
It is not sand-thru, It is done with shader/toner. It is done with spraying. Some samples will have glazing underneath and then it is emphasized with some shading.
Stain everything the center color. Seal and sand sealer. Option is to then put a coat of clear on it so you can see the color. Now shade/tone the edges with a spray gun dialed down to a small fan. Shade to desired effect. Reclear, check color match. If ok, proceed with remainder of finish system.
The transition line from the wood tone to the black is typical of the effect being sprayed.
So you know, Shaders are made with dyes.Toners will be more pigment based.
10/27/19       #4: Two-tone wood stain ...
dan shaf Member
Go to YouTube and look up how to sunburst a guitar (or mandolin). But first read again Bob's brief overview of toning & shading.
10/28/19       #5: Two-tone wood stain ...
Tony TerBorg Member
Thanks so much for the direction.
12/8/19       #6: Two-tone wood stain ...
Greg Aanes  Member
Website: gregaanesfurniture.com
I recenty was dragged into a finishing job using a WB dye with a pigment stain after that drys. Nice deep color, where can I learn more about that method as it opens up lots of color possibilities. We make furniture.
