Subject: Re: Detail glazing over TC EM6500
10/30/19
Bill Colligan Member
I am in the process of finishing a piece of worl that will be finished with Target Coatings EM6500 pigmented lacquer. The plan is to glaze the details in the sticking and profiles with a color followed by a topcoat of EM 7000 clear. Does anyone have experience with this as to what glaze would be compatable? Can I use any latex or alkalyd paint mixed with glaze or is there a different process I should use. The glaze color needs to be a violet color. Thanks.
10/30/19       #2: Detail glazing over TC EM6500 ...
Jonathan Mahnken
Most WB glazes will work. Target used to recomend the GOLDEN brand. Make sure the glaze has fully dried or it will craze under the 7000 lacquer. If your base color is light or white you should use their ultra clear formula. Also if you havent done much of this kind of glazing before, you will need to alter the consistency and drying speed to your liking through the use of clear glaze base, water, and compatible extender.
10/30/19       #3: Detail glazing over TC EM6500 ...
Jonathan Mahnken
It has also been my experience that you have to double up on the topcoat or you can have sheen inconsistencies
10/30/19       #4: Detail glazing over TC EM6500 ...
Pat
Like Jonathan said, the Golden Acrylic glaze will work. It's available at most art supply stores. You start with the clear base and mix in Golden acrylic paints to get your color. Open time is an issue. I've used Golden's Extender and Floetrol with some success. I use a Paasche Flow Pencil for detail glazing. You can fix sloppy glazing somewhat with a Scotchbrite pad before clearcoating.
Cheers,
Pat
10/30/19       #5: Detail glazing over TC EM6500 ...
You guys have been a great help, thank you. How much colorant is usually required to mix in with the liquid glaze. is there a formula? I figure I might need about 12-16 oz. of glaze. I will be doing a raised panel hope chest. Thanks again.
10/30/19       #6: Detail glazing over TC EM6500 ...
Pat
Here's a link to the product. You'll need to experiment to get the color and effect. You can use heavy body paste or liquid colors. If you use a flow pencil, it has to be pretty thin, so paste colors might not work. Do samples including the clear coat, because the color can shift a little.
Golden Glaze
