Subject: Re: Sherwin Williams Pre/Post Cat
12/4/19
Howard
Website: http://woodcontours,net
I've decided to use SW solvent precat tinted to one of their colors. Anyone have experience with their product I have generally been using Mohawk's clear finishes. It will be an offwhite color and the rep told me that their high solids lacquers could provide an opaque cover with just one coat. Seems a little optimistic to me, what do you think? Thanks for the help.
12/5/19       #2: Sherwin Williams Pre/Post Cat ...
I'm sure with the correct primer underneath the one coat promise will be kept. But what about the durability of a single coat. For the most part a primer and two coats is pretty standard.
I've done jobs early on where I did one coat on the backs of the doors and a few years later you can tell the coating was pretty thin. Once of the most tedious parts of the job is the finishing. Do it right the first time.
12/6/19       #3: Sherwin Williams Pre/Post Cat ...
Thomas
Just curious as to why you do not continue to use Mohawk. When SW bought out ML Campbell, Sherwin Williams quit selling to the woodworking industry in our area. If you are bent on using something besides Mohawk then I would look at Milese...good product with high solids.
