Subject: Re: Kremlin and CA Tech spray tips for AAA guns.... Opinions?
12/5/19
Matt
Any opinions out there about the spray/finish quality you get from Kremlin branded fluid tips vs. CA Tech branded fluid tips? The tips retrofit each other. The Kremlins cost more, but that's OK with me if you guys say that they provide a better final product. I am holding both in my hand and I cannot see anything that would set one tip apart from the other, in terms of quality.
We just bought a Kremlin (Eos 15:1) and already have 3 CA Tech (14:1) spray pumps. The Kremlin has the Xcite gun which I definitely like over the CA Tech Cougar, it does indeed seem to atomize better and leave a better finish, all other things being equal.
I have not yet tried swapping tips from one brand to another to compare them, so I figured I'd ask you guys. Do you see any difference or get better life from one tip vs the other? We typically spray a 511 CA Tech tip.
12/5/19       #2: Kremlin and CA Tech spray tips for ...
I started buying CAT tips because that's what was easily available and they were less expensive than the Kremlin tips.
I see no difference. The only difference I've noticed is physical. The Kremlin tip has two grooved around the diameter of the tip while the CAT only has one. If you use the CAT tip you have to remove the retaining clip to use it in the Kremlin gun (MVX in my case) because it's in the wrong position for it to work in the cap. So when you take the cap off you have to be aware the tip can fall out.
CAT Tips
12/5/19       #3: Kremlin and CA Tech spray tips for ...
Two grooves, not grooved.
12/6/19       #4: Kremlin and CA Tech spray tips for ...
Jared E
A couple weeks ago I needed a new tip on my Bobcat gun. The local CA Tech outfit closed a few months prior, so I got a Kremlin tip and it did not fit. The Kremlin was .010 larger in diameter than the CA Tech and would not fit my gun, even though all info I'd heard was that they were compatible. I did remove the retaining ring as mentioned by Leo, but it was too large for the recess. I ended up massaging the OEM tip to get through the job.
12/6/19       #5: Kremlin and CA Tech spray tips for ...
Adam 312
Just let me work with a pressure tank
Low tech high concept
Time tested..
adam312
12/6/19       #6: Kremlin and CA Tech spray tips for ...
Adam 312
Parts are too expensive bootleg or real
12/17/19       #8: Kremlin and CA Tech spray tips for ...
Matt
Having sprayed both a pressure pot and several brands of AAA pumps, I can assure you that the two are not a fair comparison.
In a small volume shop where you may spray occasionally, pressure pots are just fine.
But if you're spraying more than about 20 parts per day, you'll see a world of difference in your time invested with an AAA, reduced paint overspray, and overall quality of finish.
