Subject: Re: AquaPrime recoat window
1/7/20
Jonathan Mahnken
For those using Chemcraft Aquaprime Stain blocking primer... Im having trouble staying within their recommended 2 hour recoat window after sanding. The old Aquaprime had an 8 hour recoat window after sanding. The problem here is in the paint schedule.
Prime
Sand
Caulk(then wait 24 HRS for the caulk to set) This is the killer
Prime
Sand
Paint
Im either going to have to shrink my batch sizes so I can re-scuff right before painting, or im going to have to modify the schedule some how
1/11/20       #2: AquaPrime recoat window ...
Typically you caulk after priming as you have shown in your schedule. The reason why is so you can see what you are trying to fill. It’s not about adhesion. The caulk will have similar bonding to the wood/substrate itself. Caulk before you paint, then go coat to coat.
1/11/20       #3: AquaPrime recoat window ...
Jonathan Mahnken
So you are saying I sould just stack my two topcoats back to back without sanding between?
1/11/20       #4: AquaPrime recoat window ...
Jonathan Mahnken
Chemcraft Aquaset requires scuffing between coats...
    • 2Sand
