Subject: Re: Should I go Polarion
2/13/20
Jacob Member
Hey all. I'm looking for some opinions.
I finish kitchen cabinet doors, dfs, parts, etc. I'm currently utilizing MLC's Krystal and Klearvar for clearcoats, and I'm using Clawlock and Turino for pigments.
I'm contemplating whether or not I should step it up to the next level and go with Polarion to make an even more durable finish on my product.
What are other's experiences on the product?
Workability, how's it sand, dry times, completed coat feel, easy or tough to work with?
My rep tells me it'll cost me $15ish more per gallon compared to what I'm using now.
I'm going to demo it either way, but I am also curious what others think about it.
Thanks for the input everyone.
2/13/20       #2: Should I go Polarion ...
Polarion clear is nice to work with. Drying times are pretty long if you don't have the heat cranked. 75º-80º is a good temp for quicker drying. But it's still not fast. 35-45 minutes to get to dry to touch is typical.
You'll have to think about the price as about $100/gal because you need to include the price of the catalyst.
Polarion pigmented I didn't like at all. I probably needed to thin it more then I did. But I found it tough to get it to lay out nice like the clear does.
I use the clear when I have to do wood countertops. I also use it for full fill in grainier woods like Oak, Sapele and Ash. Takes time. 3 coats wet on tack, dry overnight, sand back hard. If you get it flat one more coat to finish it off. If not 3 more coats and then sand back hard til flat and then the final coat. I find for Red and White Oak it takes the 7 coats plus the initial sealer coat.
2/13/20       #3: Should I go Polarion ...
DannyB Member
For generic clearcoats like you describe, i'd go with coda rather than polarion.
Unless you use polarion fast dry, the dry time for polarion will be a little long (45-60).
If you use fast dry, the pot life is only an hour.
This is the joy of most 2k urethanes, you can choose between short pot life or short dry times.
CODA's chemistry will give you 45 minute dry times, and 4 hour pot life.
Beyond all that, i'm honestly not sure i'd bother converting to polyurethane but not moving to Milesi or something else waterborne.
While it's nice to not deal with the formaldehyde, you do have to move to supplied air or something similar to deal with the isocyanate safely, and that is a bit of a time suck.
If you can also move to waterborne, you make some of it back in being able to clean stuff up much easier.
