Subject: Re: hvlp tilting
hvlp tilting
2/25/20
pascal stgelais
Hello.
I have stumbled upon a recommendation to reduce dry overspray landing on coated surface. It is to tilt the gun in the direction of your stroke to push the overspray onto uncoated surface.
This had me puzzled since it goes against textbook technique wich is to spray perpendicular to the surface.
To be clearer here is how it works. Lets say you spray a horizontal tabletop. you picture a north/south/east/west axis over it. You spray east/west and go up north overlapping your strokes. When going west you tilt you gun slightly to the west like you would push in the direction and vice versa.
Is it worth it doing it with a Hvlp or was it just a conventional gun( high volume high pressure) trick since they produced lots of overspray.
I also use retarded CV wich take a lot longer to dry than precats. I mostly spray horizontaly and so far did not have any ill effects from spraying horizontaly. It mean I either get very little overspray or it gets melted into the still wet cv coat.
Anyone use that technique or am I trying to fix something that is not broken
2/26/20       #2: hvlp tilting ...
Shane
nope.... for those larger surfaces if your having a hard time getting it sprayed while everything still lays down with a wet edge you need to bump up and upgrade to an AAA rig..... you can absolutely fly around a table top and leave a perfect wet surface if your determined to do it quickly. It may be time to keep the cup gun for the smaller projects.
