Subject: Re: Painting over melamine board
2/26/20
Dan Cook
Website: http://rdcook.com
Have any of you painted over melamine board? I have a customer who wants melamine interiors and a different color of paint on the outside. Some of the areas can't be covered by panels so wondering if any of you have done this and did it work out in the long term.
2/26/20       #2: Painting over melamine board ...
mastercabman
I have!
Scuff/sand pretty hard
Prime with white vinyl primer!
It turned out ok but it's been years since I did it and have not going back to check how it hold up
I guess it did
I have not heard anything about it
2/26/20       #3: Painting over melamine board ...
Jonathan Mahnken
they also make melamine thats paintable on one side if you have a lot of it to do
2/26/20       #4: Painting over melamine board ...
Shane
We do fairly regular with no problems but I do run it through a widebelt machine and put an 80 grit scratch in it. Prime with conversion varnish primer and topcoat. Never had any adhesion issues. If you only have access to orbital sanders i'm sure it will be fine if you rough it up well.
2/26/20       #5: Painting over melamine board ...
They have a product that is designed for one side to be laminated and the other is melamine. I know it as Melamine with a glue back.
I've have really good results using that for painted exterior/melamine interior.
2/27/20       #6: Painting over melamine board ...
I know some guys who run it thru a wide belt and spray 2k urethane on one side and the edges.
2/23/22       #7: Painting over melamine board ...
Hailey Roberts
