Subject: Re: Ignition temp of conversion varnish
3/11/20
Al
Does anyone know the ignition temperature of cv? I want to buy a hazardous location heater for a room where parts will off gas. I generally use Conestoga brand finish which is solvent based.
Thank you,
Al
3/11/20       #2: Ignition temp of conversion varnish ...
Ignition temp in a bucket, or flash point of the perfect air/fuel mixture suspended in air? But I really don't know what a hazardous location heater is either. I designed explosion proof electrical systems for turbine natural gas compressor stations in the early 80s, but never put a heater in the enclosures.
3/11/20       #3: Ignition temp of conversion varnish ...
Al
The heater mounts on wall and is electric 220v. It comes with explosion proof thermostat that is mounted right on heater itself. I don’t think you want it directly in a spray booth but I a have a small well insulated out building where I want to put the finished pieces for maybe 48 hours to fully cure and off gas. On heater it says do not use in atmospheres where the operating temperature code exceeds the ignition temperature of the hazardous atmosphere. The operating temperature of heater is 280 degrees Celsius 536 Fahrenheit. Butyl acetate has auto ignition temp of 420 Celsius and I believe this is what most cv’s are made with. So my heater would be ok with butyl acetate by I don’t know if there is something in cv that has a less auto ignition temperature. Most of the spec sheets seem to lack this info.
3/11/20       #4: Ignition temp of conversion varnish ...
Daniel Berlin Member
Honestly, I would stick with the explosion proof boiler style here, rather than electric heater.
That seems like a really high temp to be messing around with.
3/11/20       #5: Ignition temp of conversion varnish ...
Al
Daniel,
Any brands or websites you can direct me to? The boiler interests me. Thanks
3/12/20       #7: Ignition temp of conversion varnish ...
Shane
You will not want to heat any wood products with coatings applied much passed 140F for issues of warpage. we have a 20x20x20 gas fired powder coat oven we use to force cure our finishes on rolling racks and typically run precats at 110F ..CV's at 120F 2K polys @ 135F.... After spraying they are fully flashed off before entering the oven for a cure or you will have a million tiny bubbles from solvent pop.... precats cured to stack/wrap in one hour … CV's a little over an hour and poly's minimum 3 hours cure to pack. airflow is waaay more important than temperature…. it's like an 40 mph wind tunnel inside of there when parts are curing...
