Subject: Re: Stain/glaze sealer for ceruse style hardwax oil finish
3/27/20
Paul Member
We are trying to create a professional looking cerused oak finishing schedule using water based dyes, oil based stains and hardwax oils. There are a few reasons for this - consumer perception of different finishes in our area, shortage of people who can apply spray finishes professionally etc.
Our schedule would look something like this: dar water based dye, oil based stain of similar colour, sealer, thick stain or glaze of contrasting colour to fill pores, clear hardwax oil as a top layer.
We are trying to use the same hardwax oil as a sealer since obviously we can't use any film forming substance. The problem is that it does not seem to sufficiently seal all the flat areas and all we get when applying white stain/glaze is a muddy mess.
Any advice on sealer or ceruse stain/glaze selection for this kind of application?
3/27/20       #2: Stain/glaze sealer for ceruse style ...
Sounds like a science experiment using dissimilar materials to see what'll stick. Won't the oil base cover the dye? Sorry I have no idea what a hardwax oil is. I suggest you make a bunch of sample boards, but it sure doesn't sound like a quick process.
3/28/20       #3: Stain/glaze sealer for ceruse style ...
CraigM
I've never done it (i use traditional stain/film build/glaze for my ceruse work), but I know a lot of flooring guys use Rubio Monocoat to do cerused floors. Lots of videos/ info about it with a google search.
4/10/20       #4: Stain/glaze sealer for ceruse style ...
mauricio poli Member
You can try this schedule:
Apply transparente wax
Dry and do not polish
Apply a white water based stain
Clean very well and leave the white only in the pores, you can use a rag with some mineral spirits to clean the furniture, leaving white in the pores.
Apply again the transparent wax
Let it dry and use a polish to give shine
But it is a decoration furniture, do not expect good quality furniture.
Good luck
5/12/20       #5: Stain/glaze sealer for ceruse style ...
Scott Member
@Paul which hardwax oil finish are you using?
We've done finishes for decades where we seal the wood with an oil (sometimes UV tunnel cured oil) then use solvent based dyes and glazes on top and then finish off with polymerized tung oil or UV cured hardwax oil.
