Subject: Re: cedar sap residue
cedar sap residue
3/31/20
Dan Cook
I have a cigar humidor that a customer has asked me to restore. it was made from spanish cedar and the sap has leaked all over the inside of the box and hardened. Does anyone know of a solvent that will soften it or remove it. I have tried laquer thinner, alcohol, and some others to no avail. I have scraped and sanded with minimal results as it loads up the paper immediately. Suggestions???
3/31/20       #2: cedar sap residue ...
Lacquer thinner inside a humidor is a huge no-no. I always slip in the spanish cedar so it can be slid out and touched up with sandpaper if that happens, and it always does. Is the cedar a lining? If you can't get it out, I'd miter some 1/8" thick spanish cedar and slide in a new lining over the old. No glue.
4/1/20       #3: cedar sap residue ...
Dan Cook
This is a Partigas display box that the customer wants restored. I can't really alter it as that would decrease its value. I just want to clean it up and get rid of the sap that has leaked out onto the surface and hardened over time. i tried scraping it and then sanding and that has worked the best but some places are not able to be sanded.
4/10/20       #4: cedar sap residue ...
mauricio poli
If a solvent material do not clean try a water based material, as water and soap. Or a WB stripper. Go to the other side...
