Subject: Re: Painted cabinets: Catalyzed CAB Acrylic Conversion Coating vs 2K Poly
4/1/20
Jenny Member
I am deciding between a Catalyzed CAB Acrylic Conversion Coating (with a Hardener added to it) vs a 2K Poly for spraying kitchen cabinets. My clients want the finish to mimic the low-luster look of old-world paint.
When my clients get the painted look, they usually choose a bright white, grey, light pastel colors, dark navy blue or dark green.
Please see attached photos to see exactly the kind of finish my clients want.
CAB Acrylic product name:
1. SHER-WOOD® Acrylic Conversion Coating
- can be pre-catalyzed or post-catalyzed
- used as both a tinted sealer and tinted topcoat
2K Poly products:
1. Renner Italia White Primer
2. Renner Italia Urethane Pigmented Self-Sealer ZERO SHEEN
- both of these products can be tinted to any custom colors by manufacturer
Questions
1. What are the pros and cons of each system?
2. Which one is more durable?
3. Which one is more cost-effective?
4. Which one is better for transportation between a hot, humid climate and a dry, colder climate?
5. Is the Sherwood catalyzed CAB Acrylic Conversion Coating a solvent-based or water-based product?
6. If none of the products I am considering is suitable for my purpose, what other products do you recommend?
View higher quality, full size image (900 X 1200)
View higher quality, full size image (1000 X 1295)
View higher quality, full size image (474 X 640)
4/3/20       #2: Painted cabinets: Catalyzed CAB Acr ...
Daniel Berlin Member
This is a very detailed set of questions, wanted to make sure you got *some* response.
Here's the short version of an answer to some of your questions:
CAB lacquers and 2k urethanes are not even in the same planet in comparing durability/etc. The urethanes will blow away the lacquers. You will pay more for this
It is also very easy to get dead flat urethanes (IE 5 sheen, etc), harder with lacquers.
The rest of your questions are hard to answer because they are very subjective.
Cost-effective depends on whether you are optimizing for your straight cost, etc.
Also, the sher-wood line you mention is solvent based.
4/7/20       #3: Painted cabinets: Catalyzed CAB Acr ...
Jenny
Thank you Daniel.
I just ordered samples from Renner’s distributor MK Sales. I’ll definitely update everybody here about my experience and result with Renner.
4/8/20       #4: Painted cabinets: Catalyzed CAB Acr ...
One thing i didn't touch on that may be worth knowing - the lacquers would probably be much more forgiving of bad prep/priming/etc than the 2k urethanes.
They will not bond as easily, so the use of proper prep/sealers/primers is often very important.
If you want to see what happens otherwise, you can see pictures of 2k urethane delamination on houzz's flooring discussions and watch the flooring installers blame the products rather than improper prep :)
4/8/20       #5: Painted cabinets: Catalyzed CAB Acr ...
Jenny
What are the more proper ways of prepping and priming? And how do most people screw up?
I have started a new post titled “ Rank multiple 2K poly finishing schedules”, which includes 6 finishing schedules I have observed from professionals from multiple countries.
I would love to get your opinions on things and at the same time, I hope my new post would inspire new ideas.
4/8/20       #6: Painted cabinets: Catalyzed CAB Acr ...
"I have observed from professionals from multiple countries"
Jenny,
What is your business, job description, experience, general background?
4/8/20       #7: Painted cabinets: Catalyzed CAB Acr ...
Jenny
Hi Adam,
I am British. I am in my twenties. I live in the US now but I lived in Asia and Europe when I was younger. I can speak multiple languages.
My family owns a hotel chain and I own a humble kitchen cabinet business here since my husband likes woodworking. I moved to New York for a banking job after graduation but realised later that I like interior designs better. Now I work on small construction projects here on the west coast.
Now you have to tell me about your background &#128523;
4/8/20       #8: Painted cabinets: Catalyzed CAB Acr ...
"What are the more proper ways of prepping and priming? And how do most people screw up?"
To be honest, most people screw up by not following the directions on the product sheet to the letter.
Let me give you a practical example of differences -
With lacquer, you can stain stuff with a lot of different stains, and assuming it cured properly, it'll probably work to spray stuff over it.
If you are doing solid colors, you can use just about any primer, and it'll work. I'm overselling, but they are fairly simple.
With 2k urethane, you almost always must use sealer coats over stains. The types of stains you use *must* be compatible with the sealer.
Similarly, for some brands, they require certain primer kinds be used with certain topcoats.
Most 2k urethanes also have explicit directions on what grit to sand to before applying sealer or topcoat, etc.
Most lacquers have the same, of course.
However, if you ignore the lacquer directions, you can get away with it most times.
If you ignore the 2k urethane directions, you will rarely get away with it. It will probably fail.
4/10/20       #9: Painted cabinets: Catalyzed CAB Acr ...
mauricio poli
Let me answer your doubts:
1 - ready to use material is easier to use because one just apply and wait to dry. It is ok when you work with low profile people that do not know how to read and follow instruccions. But it has low solids and need to apply more coats to give the quality you want.
PU system is ok ONLY if you follow instrucctions. Need to do EXACT what say the techinical data sheet. In the end of the day all the left mixtures go to the garbage can. But it worth because you apply less coats and have less overspray loss.
One coat of PU is equal 2 coats of direct material (more or less)
2 - PU will resist better than others materials.
3 - PU has better cost/effectiness
4 - You need to wait 24 HOURS to package your furniture. It will resist with no problems since you follow TDS
5 - CAB Acrylic 2K is solvent material. This material will be more used in open pore finishes. Your pictures is PU system, closed pore.
6 - In my opinion use PU only. I used Renner in the past and it is a very good material, ask help to your distributor they are good people.
    • 2Sand
