Subject: Re: Complete finishing system? Polyester
4/16/20
Craig Member
Hi all. I need a complete finishing system for my acoustic drum business.
Currently I have been using various finishes, pre/post cat lacquer, waterbased finishes, conversion varnish and a UV cure product.
I can get a satisfactory satin result with most of those finishes, and get the high gloss/high build look I want with the precat lacquer (especially with two tone paint jobs using lacquer tints) but having checking issues over time.
Sending products to other parts of the planet can raise some issues that I'd like to avoid going forward.
I want to try polyester as its what major drum/instrument manufactures use.
Can anyone give me a guide on using polyester?
Im considering Ilva or maybe simtec products, but it may boil down to what I can get here in Canada.
Anyone got a step by step process from bare wood to a mirror shine I can follow?
Gun tip size?
What about tinting?
Advice very much appreciated!
Thank you
Craig
PS. - Attached a pic of a two tone drum, tinted lacquer to colour, machined through to raw wood top and bottom and cleared over top of all.
View higher quality, full size image (1470 X 998)
4/16/20       #3: Complete finishing system? Polyeste ...
mauricio poli Member
A long time ago we finished a lot of this using NGR Stain and PU sealer and PU Top Coat. It was to export. So I believed it works well. Why donīt you search for a Renner representative near you, they have good PU stuff.
4/16/20       #4: Complete finishing system? Polyeste ...
2K poly uses basically normal spray equipment. Polyester is a 3 part system that really requires specialized equipment that automatically mixes for you - spendy.
4/16/20       #5: Complete finishing system? Polyeste ...
Chris
I spray Ilya polyester in small batches using a 3M gun with a 1.8 tip. Potlife is only 30 mins so you have to work quick.
I then seal using 2K urethane and topcoats using a kremlin AAA.
Make sure you wear proper PPE as polyester stinks when you spray it
