Subject: Re: CV over epoxy
CV over epoxy
4/17/20
nicko
Hi
I have my first live edge river table to build and have it in the form ready to pour on Monday. Will CV adhere to the epoxy and what grit should i sand to before i spray it? I usually spray SW water white CV and self seal.
thanks..........nicko
4/17/20       #2: CV over epoxy ...
Jared E
Because of the huge number combinations of epoxies and CVs, your best choice is to make a test panel and see what happens before you commit. I'd suggest waiting an extra day before shooting to allow more cure time, maybe more if it's a deep pour. I sand to 220 before shooting CV. A West Systems guy told me when in doubt, wipe it down with white vinegar to neutralize ... something to do with unbonded hardener looking for something to react to, etc., chemical stuff that I can't remember, then follow it with denatured alcohol.
4/17/20       #3: CV over epoxy ...
Good luck with your first pour. I'm more familiar with small pours that woodturners do. I see that fraught with disaster and lots of experimentation. Even seen a video where the whole table cupped from the uneven cooling of all that resin. I'd be scared $hitless doing that to some really expensive slabs!
4/17/20       #4: CV over epoxy ...
nicko
i bought epoxy that is made for a deep pour. up to 2 inches. I am pouring 1 1/2 inch.
It is not an expensive slab its a cheap slab of hemlock that some friends of mine got somewhere. I have it all clamped down in a form that i built. I checked the moisture with my meter and it was about 7 percent.
I also sealed the live edge with some quick dry epoxy.
4/19/20       #5: CV over epoxy ...
rescraft
Have a hair dryer or a heat gun at the ready for the micro bubbles that may occur. God luck and show how it came out.!
4/19/20       #6: CV over epoxy ...
Nick
I've sprayed CV over epoxy a number of times without any issues. I sanded the epoxy well with either 320 or 400 grit paper using a RO.
4/19/20       #7: CV over epoxy ...
nicko
I poured the epoxy today so i am going to let it in the form for a week then sand it down and spray it.
    • 2Sand
