Subject: Re: Super durable finish for mechanics service counter.
4/20/20
James
Looking for finish recommendations for the surface of a mechanics service counter. Will have regular contact with auto parts and associated chemicals/fluids. Preferably something that does not require spraying.
Thanks!
4/20/20       #2: Super durable finish for mechanics ...
Tom C
James
Done dozens of auto dealers and supply house service counters. A buddy is the Service manager for an auto group.
The only thing that will hold up up is 16 Ga. over plywood-Stainless steel. I have the local sheet metal shop brake it when needed.
The last one - Got 1/8" aluminum Diamond plate,with alum angle srcewed on for the edges.
Was the industrial look they wanted, will hold up to the alternators and transmissions drag across.
4/20/20       #3: Super durable finish for mechanics ...
James
Thanks Tom. I expect that is the best solution. I was initially thinking an epoxy, but I think I'll go with your suggestion.
4/20/20       #4: Super durable finish for mechanics ...
Once got a call from a Lexus dealer. They remodeled and had a shop do a mahogany reception counter. They wanted to know how to remove ball point pen impression from the wood. I told them to call the shop that did it, have them sand and refinish, then have a sheet of glass made to cover the wood. No place for wood in your application either!
