Subject: Re: Kremlin cleaning advice
4/24/20
James Knowles
Looking for best and fastest method for cleaning my kremlin as well as my gravity feed when using water base.
The finish suppliers always say clean with water. Even if I clean with water immediately after spraying i believe that I am not getting it all. Could be all in my head.....I always start with water, then lacquer thinner / acetone 50-50, then flush with water.
So I am seeking advice as to the best method for confident cleaning. I don't like the idea of using solvent in my water base system, but it cleans well.
just jim
4/24/20       #2: Kremlin cleaning advice ...
herb johnson
plain and simple go with acra strip best wb clean out there in the market
good luck
herb j
4/24/20       #3: Kremlin cleaning advice ...
Brewster
I have been using Citra Clean concentrate degreaser. It comes in 1 gallon containers and priced about $35. We use a 15-1 solution pumped through the pump, hose and gun.
Inspected pump and is super clean. I also use this solution in our Crest ultrasonic cleaner, really makes spray gun cleaning easier
View higher quality, full size image (924 X 924)
4/24/20       #4: Kremlin cleaning advice ...
James Knowles
Thank you both, Jim
4/27/20       #5: Kremlin cleaning advice ...
Kevin Member
+1 for Acrastrip. 600 B/G is what I use. Works on waterbased, CV, 2k poly, etc.
4/28/20       #6: Kremlin cleaning advice ...
dar
never heard of this stuff, it will break down CV and cat lacquer?
4/28/20       #7: Kremlin cleaning advice ...
Kevin Member
Acrastrip breaks down everything I have tried so far. I don't use it for daily line flushing, just periodic maintenance cleaning and in the ultrasonic cleaner for tips and parts etc. Mix 50/50 with water. Great stuff.
