Subject: Re: Make Kremlin Xcite trigger softer?
4/29/20
Brian E Acree Member
Hello all, my name is Brian and I'm new here. I have a Kremlin Xcite 120 and compared to my older MVX the trigger is so much more difficult to pull. Im sure it will break in more over time but I've been using it for 3 mos and it hasn't improved. Does anyone know of a way to make it more sensitive? I tried taking an older spring and taking a coil out of it but then it wasn't long enough to push back and stop the spray. So ultimately I know I need a spring of the same dimensions but with less recoil. I'm just wondering if anyone has ever successfully changed this. Thanks!
4/29/20       #2: Make Kremlin Xcite trigger softer? ...
herb johnson
the problem you have is this, the mvx 60 was rated for 60 bar or approx 900 psi and was typically mated to the 10-1 blue top pump and thus needed a weaker spring than the xcite 120 rated to approx 1800 psi which is typically pared with the 15-1 eos, i went and just looked at my manual and the lowest psi model xcite gun is the 120 so basically there is no change out available for a lower pressure spring. the purpose of that spring is to supply enough force to overcome the pump pressure to push the ball tip against the seat. i kind out doubt you will experience much less trigger force overtime but the trigger pull is really for me not a big deal
good luck
herb j
4/29/20       #3: Make Kremlin Xcite trigger softer? ...
Thx Herb that explains it nicely!
