Subject: Re: 2k pigmented waterborne over aquaprime
5/2/20
Al
I have read on Woodweb a lot of guys really like Chemcraft aquaprime. I am considering switching to Milesi or similar brand 2k poly for kitchens but the Milesi 2k primer is kind of of a deal breaker for me. The pot life is just too short for me to be practical. Milesi does have a primer that you don’t mix with catalyst but they don’t recommend under the 2k. Really don’t like mixing different brands but researching this.
Thanks for any input,
Al
5/2/20       #2: 2k pigmented waterborne over aquapr ...
Daniel Berlin Member
2k's are tricky to adhere. I generally would not mess with required primers/sealers without talking to techs, or a lot of testing.
5/2/20       #3: 2k pigmented waterborne over aquapr ...
Do you really want to take the chance of going out of system or manufacturer recommendations and have a finish failure after all your hard work.
Don't be foolish.
5/3/20       #4: 2k pigmented waterborne over aquapr ...
Al
Just researching I don’t intend on doing a project until fully confident. I find cv is probably the best but I can’t stand the off gassing of it.
5/3/20       #5: 2k pigmented waterborne over aquapr ...
Chris
I use Ilva 2 k urethane.much better than CV.
Very easy to use.
5/4/20       #6: 2k pigmented waterborne over aquapr ...
JaySun
If you are using Milesi 2K WB then that should work fine over their Universal WB Primer.
5/9/20       #7: 2k pigmented waterborne over aquapr ...
Tony Allsup Member
I use Chemcraft Aquaprime under the Milesi 2K waterborne on just about every cabinet project. Never had an adhesion issue as long as you stay in the 6 hr redcoat after sanding. Have also used it under Ilva and Renner with no issues.
6/7/24       #8: 2k pigmented waterborne over aquapr ...
Rick Cantwell Member
Tony
what do you mean by this ?
"as long as you stay in the 6 hr redcoat after sanding."
I use Aquaprime almost exclusivly as well, but havent heard anything about what your saying here
