Subject: Re: Pallman Magic Oil on Furniture and Cabinetry
5/12/20
Scott Member
Does anyone have EXPERIENCE using Pallman Magic Oil 2k on furniture, cabinetry and architectural millwork? How did it do? How did you apply it? Would you recommend it?
For those that don't know Pallman Magic Oil is an amazing hardwax oil finish to give a natural look to hardwood floors. Big following in Europe and making headway in the US.
Interested to hear actual experience anyone might have. At $150 for the basic size that is a little spendy for me to just buy and play with.
5/12/20       #2: Pallman Magic Oil on Furniture and ...
What makes it amazing?
5/12/20       #3: Pallman Magic Oil on Furniture and ...
DannyB
Uh, so, not sure what is supposed to be a "hardwax oil finish" (whatever the heck that means) here.
Component B is 100% a pretty standard 2k urethane.
From http://www.pallmann.us/uploads/tx_dddownloadmatrix/Magic_Oil_2K_A_B_SDS.pdf
1,6
-Hexamethylene diisocyanate homopolymer - 75-100%
5/12/20       #4: Pallman Magic Oil on Furniture and ...
mauricio poli Member
It works very well, better if you apply one coat, let it dry, sand , apply again.
Never put solvent on.
It is an oil hardened with poliurethane
5/12/20       #5: Pallman Magic Oil on Furniture and ...
What's the oil and how do you harden the oil with polyurethane?
5/13/20       #6: Pallman Magic Oil on Furniture and ...
Daniel Berlin Member
As rich is kinda poking at, what is being said here does not make any sense chemically.
Additionally, nothing that would be in a traditional oil shows up in the part A MSDS.
(depending on the type of wax, it would not be reportable)
That doesn't mean this stuff is good or bad, but honestly, as far as i can tell, it's just a urethane with some random crap added.
Calling it *anything else* is just marketing :)
All protection/etc here is provided by the urethane polymer.
You should compare it accordingly.
5/13/20       #7: Pallman Magic Oil on Furniture and ...
Yup, a long history in finishes where we've been told it's oil and it's really varnish. Anytime "amazing" gets used in the description, I envision snake oil. I did a little more research and some of those hard wax oil finishes takes hours to dry. That's nothing I would want in a commercial shop. I also prefer a finish that doesn't need frequent repairs, no matter how easy the repair is. Let's just start with a tough finish and go from there.
5/13/20       #8: Pallman Magic Oil on Furniture and ...
Scott Member
@Mauricio Thanks for the response. What do you use to apply the oil? Do you apply it wet and heavy and then wipe it off?
For the other questions... briefly, as I want this thread for people who are actually using it it - Pallmann Magic Oil is a flooring finish with lots of good history in Europe and the US including in some intense commercial environments. I heard about it from a flooring guy in midwest that has done 50-100 flooring jobs with it and likes it. https://napervillehardwood.com/blog/the-hardwax-oil-experiment-part-4-pallmann-mag
ic-oil/
BTW I don't sell it. I'm just looking to try it for furniture and millwork.
5/14/20       #9: Pallman Magic Oil on Furniture and ...
Hi Scott!
Apply with a brush, not so wet, and after clean well with a rag. Let it dry and sand with 360. And repeat again one or two times, it depends the quality you want.
