Subject: Re: Graco merkur tsl
Graco merkur tsl
6/2/20
Ghealy Member
I have a Graco merkur 15:1 AAA. It seems like I am getting throat seal liquid sucked from the wet cup into the pump itself. I am getting terrible fish eyes and when I flush with water, oil is floating on top when I spray into a clean cup. Any advice on how to seal the wet cup from the pump. It was re packed a month ago.
6/2/20       #2: Graco merkur tsl ...
herb johnson
if you just re packed the pump my bet is that your piston rod is shot as the chevrons are not sealing against the rod as the diameter of the rod has been worn down are there any groves on the piston rod that you can feel with your finger nail
or that the packings and wavy springs were installed incorrectly.
good luck
herb j
