Subject: Re: CV over tinted vinyl primer
6/6/20
Mastercabman
Hello everyone
I think I know the answer to this but would like to make sure it's possible
I usually like to tint my primers to the desire color and then put on a clear coating
I've been doing that for a while now
I like it better when spraying on site especially when I have a lot of vertical areas
The clear lays better than pigmented top coat(my personal opinion!)
But in the past I've always used vinyl primer with Magnaclear as a top coat(I use ML Campbell)
But I would like to use a CV like Krystal
Now I know I can put CV on top of white vinyl primer when it is catalysed (1% ratio)
But if my vinyl primer is tinted,will it still be ok to use a CV as a top coat?
6/8/20       #2: CV over tinted vinyl primer ...
Daniel Shafner Member
You can use Krystal or the pigmented post catalyzed coatings (Resistant, Stealth, or Turino) over your vinyl sealer even if you don't add in the 1% catalyst to the vinyl sealer. It's only in recent years that ML Campbell has been suggesting to add 1% catalyst to the vinyl sealer and the vinyl primer. Years ago we laid down vinyl, no catalyst, and then topcoated with precat, post-cat, no problems. A rub through? Simple, spot spray the rub through with clear vinyl sealer or pigmented vinyl primer, scuff, and recoat with topcoat.
