Subject: Re: spray dye stain with aaa
6/10/20
pascal stgelais
Can you spray dye stain with AAA. or would a hvlp yield better results.
I so wich tipa do you use. I have a m207 and a m211 on hand. I tried the m207 but the dye almost seemed to dry before even hitting the wood. Should I try bigger tips or do you guy use a hvlp for this
6/10/20       #2: spray dye stain with aaa ...
chris
i use a pressure pot and hvlp gun. 1.0 tip.
6/10/20       #4: spray dye stain with aaa ...
Mastercabman
When spraying dye or stain, you're better off with a spray gun (P. Pot or gravity)
1.0-1.2 tip
I keep my pump for thicker materials
6/13/20       #5: spray dye stain with aaa ...
MarkB Member
Been spraying stains with a 3M accuspray and really like being able to have multiple colors sitting ready in the cup just shake them up and go and the cleanup is a breeze with pretty very little solvent. I like the PPS for being able to put the gun in any position or run a small cup for tight spots. I was very skeptical but have really enjoyed the setup for swapping between colors and materials quickly especially for stains.
6/14/20       #6: spray dye stain with aaa ...
Definitely use a gravity gun. The high quality inexpensive ones like the Astro/Starr guns are perfect. Very controllable, really good atomisation, easy to refill and clean. What’s not to like?
If anything you want a lighter smaller fan than aaa.
We used to have a nice little Astro mini gun which was a Sata copy. It was really good for adding a little bit more here & there. Almost like airbrushing.
6/14/20       #7: spray dye stain with aaa ...
pascal stgelais
thanks everyone for your answer. I think that I will have a good reason to keep my fuji hvlp ready
