Subject: Re: Staining both sides
Staining both sides
6/18/20
corey toyama
I know that the conventional wisdom is to finish both sides, especially for a table top. Does this go for staining too? Will staining one side only cause an imbalance just as finishing one side only? In this case, I am using a General Finishes gel stain, however would be interested to hear if this depends on the type of product.
6/18/20       #2: Staining both sides ...
pascal stgelais
Most stains containt little binder so their "sealing" effect would be minimal on moisture imbalance.
With water based stain you could create cupping on a thin panel but it would result from water imbalance and it should return to normal when dry.
I often stain only one side and never had a problem. with finishing I have seen panels always cup in the same direction(unfinished side)
6/18/20       #3: Staining both sides ...
No one stains unseen parts. Stains are color pigments suspended in solution. There is little to no resin to harden which would provide a film to limit moisture intrusion. There is so little resin/hardening that stains will often lift if hit with a solvent.
You don’t need to put the same number of topcoats on the bottom. 1 heavy sloppy coat of shellac, poly or your favourite goop slathered will work.
6/18/20       #4: Staining both sides ...
Depends if we are talking furniture or cabinets. I will stain both sides of a dining table as I expect someone to crawl under it with working leaves.
