Subject: Re: finishing walnut
finishing walnut
7/22/20
Georgerobert Member
Website: https://mocphat.vn/san-go-oc-cho/
Is there a finish or treatment one can finish walnut with to prevent the wood from turning the patina color it normally turns to with age, keeping the original color?
7/22/20       #2: finishing walnut ...
pascal stgelais
there are some uv resistant finish that some folks here will be able to tell yoi about more than me.
otherwise from what I have read almost everywhere there seems to be no definitive method that can prevent wood color from changing over time.
I think the easiest way would be to use something like an oil wich can be sanded an recoated as often as possible.
you could also stain the walnut.
keep it away from direct sunlight if possible
7/22/20       #4: finishing walnut ...
Jim Clark  Member
I have actually stained walnut with a walnut
stain to keep it more black. Seems to work
without changing the color much at first.
7/22/20       #5: finishing walnut ...
JeffA
If you are more concerned about color change then maybe use a wood like ash and make it the color of walnut. Of course, it depends on what the product is but I have done that many times in ceiling and wall products.
7/22/20       #6: finishing walnut ...
You can't fool Mother Nature. The Holy Grail is to have wood that never changes color and never moves. Just ain't going to happen.
7/22/20       #7: finishing walnut ...
I do what Jim does. I take Woodsong tinted to American Walnut and thin it to about 50% with stain base. This gives a good Walnut color that is pretty natural and last for as long as I've seen.
7/23/20       #8: finishing walnut ...
As Rich said you will get some change no matter what, but the best results I have seen over many years is to stain the walnut first , use a stain as close to the natural color as possible.
    • 2Sand
