Subject: Re: Thinking of going waterborne
9/20/20
mastercabman Member
I have been spraying solvent based finish for many years
Lately I've been asked to paint more than just kitchens
Like bookshelves,built ins, moulding like crown,casing, chair rails, wainscoting etc...
Spraying solvent based finish is not ideally good inside the house
Too hard to ventilate and to keep the smell out
So I like to switch to waterborne,and for many other reasons
So I have my spray equipments
Gravity feed gun, pressure feed gun,and a CAT pump peak 14-1
Am I going to be ok with my equipment?
I do realize that I need to run lacquer thinner,then denatured alcohol,then water to switch before using the waterborne
Is the cleaning of waterborne easy on the pump?
I will most likely be using ML Campbell product
9/20/20       #2: Thinking of going waterborne ...
Just so you know waterborne smells too. Granted it's not as bad. Even fully cured UV coating has a distinct smell especially if you close off the cabinet and the smell builds inside.
9/20/20       #3: Thinking of going waterborne ...
mastercabman Member
Thanks Leo
Yes I know it smells too
I have used waterborne before and the smell is not as harsh as precat or post cat
But I don't recall the waterborne to linguer as much as solvent
9/20/20       #4: Thinking of going waterborne ...
Daniel Berlin Member
Waterbornes often smell less, but there is large variation in whether it is safer for you.
A lot of the chemicals involved do not have as strong a smell except in higher concentrations, which convinces people they are safer, regardless of whether they are or aren't
I've seen plenty of cases of people doing really harmful things with waterbornes because they take less precaution than they did using solvents.
Like anything else, you need to look at the SDS and actually go and understand the safety to yourself of what you are spraying.
10/8/20       #5: Thinking of going waterborne ...
Pat
Waterbornes will spray fine out of your CAT AAA (that's what I use, too), and will give you the best transfer efficiency and least overspray. I use an .009 or .011 tip. Obviously, waterborne is much safer with regards to flammability.
Cheers,
Pat
