Subject: Re: UV treatment for already finished cabinets
10/2/20
Ken Seidman
Website: http://www.seidmanwoodworks.com
Does anyone know of a way to add UV protection to already-finished and installed cabinets?
We have an already-installed project. The panels are an Italian bleached and dyed veneer (Tabu is the company that makes these). We finished these with a conversion varnish with UV inhibitors.
There's a not-unexpected yellowing resulting from the resins in the finish. But in addition to that the dyes in the veneer are washing out, due I think to UV light.
Is anyone familiar with a process for enhancing the uv protection of an already-finished product? Would a polish or wax with uv protectants have any effect? Would a clear coat over the existing CV, using a finish with better UV protection, increase the UV protection?
I'm about to do a bunch of tests, but would appreciate advice with anyone who has experience with a similar issue.
10/2/20       #2: UV treatment for already finished c ...
DannyB Member
Do you want to reverse the yellowing, or protect it from more yellowing?
10/2/20       #3: UV treatment for already finished c ...
rich c
Have them install film or UV blocking screens on the windows. Not all dyes, nor all colors of dye, are light stable.
10/3/20       #4: UV treatment for already finished c ...
Bart
Your problem is probably the dye stain. Unless it's a metalized dye it'll wash out ASAP in a sunlight challenged area. I used Lockwood dyes back in the day and learned the lesson the hard way. Looked great but....didn't last with any exposure.
That said as Rich said get them a window treatment. Even a pigmented stain with high exposure will fade. Red tones especially susceptible in all types of stains.
At one time I recall General Finishes which I use exclusively offered a UV option to their WB interior finishes. I never tried them so I can't comment. Check with your MFG.
Worst case if possible would be to do an on-site touch up with either a tinted topcoat or a toner wash coat/s to bring the color up to speed and top coat with UV enhanced topcoat.
Either way a bit of a cluster.
good luck
my2cts
10/5/20       #6: UV treatment for already finished c ...
Ken Seidman Member
Thanks for your replies.
Danny B, My aim is to protect the finish from additional yellowing/fading of the dyes.
Rich C and Bart, thanks for the UV blocking window treatment suggestion.
I'm prepared to do some toning where damage is worse, if required, but my hope is to arrest the yellowing/fading process so that the shift in color remains at a level acceptable to the client.
I selected for the project a conversion varnish with UV inhibitors, but that clearly was insufficient.
I wonder if there isn't the equivalent of sunscreen that can be hand applied, like a polish, on top of a finished surface. I googled this and saw some products but am reluctant to apply them without consulting someone who has had experience with them over the long term.
10/5/20       #7: UV treatment for already finished c ...
rich c
You aren't going to stop the dye from changing since it's already shown a tendency to fade. Nothing totally blocks the UV, even UV resistant finish.
4/27/21       #8: UV treatment for already finished c ...
Jim Knowles
You have two items that can color shift. The dye and the wood. Wood can change just by being exposed to oxygen. Sun light can change the color in a matter of hours. Take old raw cherry or teak. The older it gets the darker it gets. Run both through the planer and see the difference. Especially the teak. It went from deep dark rich brown to light yellows and green stripes?? Set it in the sun in the morning. By that afternoon it will be so brown you won't think it is the same wood....!
Got to love it
just jim
