Subject: Re: Portable AAA pump
Portable AAA pump
10/11/20
mastercabman Member
Hello
I am starting to pick up more finishing jobs and need to be more efficient
I do on site kitchens and bathrooms refinishing
I spray the cabinets in the house but I spray the doors and drawers in my trailer
I have a pump(CAT 14:1 peak)that I love
But it is a wall mount so I made a cart for it to move around but I would like to permanently mount it in my trailer and then get another pump to use elsewhere
I have been looking at some of those pumps that are mounted on a cart and has it's own compressor with it
CAT has one that is the same pump that I have now.it is mounted on a cart and has a 4 gallons compressor
I also checked Graco and they also offers pumps like that
Does any of you own or used one of those kit?
Do you like one more than other brand?
Is the compressor loud?
Pros and cons?
10/12/20       #2: Portable AAA pump ...
Shane Welch
I've had the cat cart pump with compressor and it was a fine workhorse for hundreds and hundreds of gallons of coatings sprayed.... I'd say it's a very cost effective rig and the compressor is just right for the task...... it really keeps up with the gun without any issues... it's not perceivably loud either like some crappy oilless compressor..
10/13/20       #3: Portable AAA pump ...
mastercabman Member
Shane
Thanks for the info
Does the unit comes with an air filter?
If not did you add one?
Or does it do just fine without it?
10/13/20       #4: Portable AAA pump ...
Shane Welch
As much as I recall it is not filtered.... you could always run a bulb type before the gun to catch particulates or condensation.. best I can remember I never had any contaminated air issue nor very much condensation issues.... Even in the southeast in humid weather. Just drain the tank regularly...
