Subject: Re: CODA Primer
CODA Primer
10/24/20
Jacob
I just tried out Coda primer.
Im used to working with MLC's clawlock. The coda primer seemed much thicker.
I use a airless air assist pump. Only had a tip size of .413 in the shop.
In order to get the coda to spray right was by reducing it by almost 50%.
The film build was extremely thick.
Anyone who has or is working with Coda primer, do you have any tips, suggestions, or recommendations?
I want to make this work but I'm struggling.
10/24/20       #2: CODA Primer ...
Jared E
I'm also dealing with a very thick primer at the moment, Rudd Miravar surfacer. I had to turn up pump pressure quite a ways, thin it by 15%, and get a bigger tip for my Graco G15. I was using a 413 (8 inch fan, .013 orifice) and went up to a 515. After cleaning the junk out of the fluid filter on my gun, it sprayed out fairly well.
10/25/20       #3: CODA Primer ...
DannyB Member
CODA primer is pretty thick (not as thick as clawlock but ...).
It already by default needs to be reduced 20% anyway.
I've sprayed it with a pressure pot before, but not AAA.
Some dumb questions:
1. What is your fluid pressure?
2. What are you reducing with? (PS3 medium? ps1 fast?)
3. What is post-reduced viscosity?
Clawlock II, once reduced to a sane spraying viscosity, is usually 40-50 seconds Ford 4.
Level primer is actually the same.
That is what i would target with coda primer as well.
If you look over at CAT's settings for AAA for those, they have the same settings for clawlock ii and level primer once reduced to 40-50 seconds Ford 4:
409 tip, 560psi fluid pressure.
I would start there if it's not working well.
10/26/20       #4: CODA Primer ...
Shane Welch
You answered your own question.... change your tip size to at least a .15 thousandths for thick bodied materials.... Move up in tip size before reducing materials or your missing the whole point of spraying high solids materials.... reducing to make it spray out of your equipment means less solid content left on your substrate...
10/28/20       #5: CODA Primer ...
Jacob
Thanks for all the pointers everyone.
Reason i want to make CODA work is because my mlc rep claims that i will have very little if any hairline cracks on the painted mortise & tenon joint on the face of the door.
So my other question would be, is what my sales rep claims, true?
Additionally if it is true and im afraid of too thick of a film build (worrying about bridging between panel and rail), would me reducing it down a ton lower it's effectiveness in preventing the mortise tenon cracking?
10/29/20       #6: CODA Primer ...
DannyB Member
This is in theory true.
CV's are very hard and not very flexible and can't be stretched really without breaking.
PU's are *much* more flexible and can be stretched before they break.
This should result in less hairline cracks caused by movement because it will stretch rather than crack and pull away
