Subject: Re: Varnished dresser with sun ray effect
10/30/20
Rob Forlong
I have a old antique dresser that I wish to strip. Condition of varnish is old, dry and cracked. The drawer faces have a shadow run ray detail that I’m not sure how it was created. If it was a new vintage I would think the effect could be done via air brush. But this piece is at least 70 years old. I’ve been stripping the old varnish with a blend or xylene, isopropyl alcohol and acetone which worked well on the top, simply rub with steel wool. Does not raise the grain at all. I’m afraid to do the drawer faces as it might remove this sun ray effect. Your input would be appreciated.
10/30/20       #2: Varnished dresser with sun ray effe ...
kevin basto
The "sun ray' your talking about is basically controlled burning or toasting of the veneer before the pieces of the marquetry are put together, the pieces of veneer are toasted in hot sand until the desired shade is reached. It would be very hard to rub it out, your piece may also be finished in shellac which is fairly easy to repair.
