Subject: Re: paint booth floor
paint booth floor
11/11/20
scott
Hi we are setting up a new paint booth to spray conversion varnish and wondering what product to spray on concrete to help cleanup or protect from buildup. Is it even possible, our last booth we had to grind the floor to remove the buildup when we removed the booth. Should we even be concerned, thanks for any info.
11/11/20       #2: paint booth floor ...
chris
https://www.chemcomfg.com/products/floor-coverings/
they offer different papers to cover your floor
I would spray an epoxy coating then use this to protect the floor
11/12/20       #3: paint booth floor ...
mike
i saw a booth a few weeks ago that used synthetic roofing paper & they said it lays flat & makes barrier for the floor. dang & when i think i was smart someone shows me something new. so that's what we are going to instead of heavy paper floor shell. good luck
11/13/20       #4: paint booth floor ...
Shane Welch
We Use #30 weight roofing felt taped down at the seams with black gorilla tape.... Last 6-12 months x 0ver 12 open faced booths and a few fully enclosed with heavy daily use and has a UL Rating......
11/21/20       #5: paint booth floor ...
scott
I would also recommend a floor protection covering similar to the rolls of Ram board that you can buy from places like Home Depot. Tape the joints and the edges .
I have also seen a booth where the guy laid down 1/8 inch hardboard and taped the joints. You want something that is not a hindrance if you are rolling items to be sprayed on carts.
11/29/20       #6: paint booth floor ...
Alex Shawn Member
I agree with other fellows. You may buy a floor protection paper to reduce your mess. From my experience, I left it on my floor for almost two months in a very high traffic area, and I only had to repair a few very small tairs with painter's tape.
12/1/20       #7: paint booth floor ...
scott
Thanks everyone for the suggestions. Are you able to sweep out the floor with out creating a bunch of loose fibers off the flooring material. Any other issues to be aware of as far as cleaning the felt or paper?
2/21/22       #8: paint booth floor ...
Mark Davis Member
