Subject: Re: Improving CV with heat??
12/22/20
Jim
I am curious weather heating CV would improve the end results or have no effect on the finish?? Just looking for any meathod to improve my CV. Not having any problems...just looking..
Thanks jim
12/22/20       #2: Improving CV with heat?? ...
Robert Member
I used to wrap an Industrial Heating Pad around the pressure pots and found the coating flowed out smooth as Butter.
12/23/20       #3: Improving CV with heat?? ...
Improve the finish? As Robert mentioned you can warm the finish in cold environments to promote normal flow out and leveling. Are you thinking baking the finish will make it more durable?
12/24/20       #4: Improving CV with heat?? ...
mastercabman Member
We used to sell Kraftmaid cabinet and I think I read their catalogue that says they "bake" their coating
I think they call it Durakraft or Duracoat?
All I can say is that I did noticed some imperfections on their finish like little craters
Maybe from a tiny bubble that popped?
Can't tell you if doing that really makes the coating stronger but I think it helps the coating to dry and cure faster?
12/25/20       #5: Improving CV with heat?? ...
Daniel Shafner Member
Baking a finish is usually done to speed up the cure time of the finish so that you can sand or stack the parts that have been finished. This has to be a decision properly thought out.
The alkyd-aminos found in some of the ML Campbell's coatings don't survive baking, meaning your newly applied fancy finish will have its durability taken away from it, compromised, by its exposure to heat. In this case, some of the ML Campbell hierarchy of gurus think that 140 degrees is the top baking temperature. Yet for inline heating, 110 degrees and is suggested.
In line heaters serve the function of reducing the viscosity of the coating without having to add solvents to do the same. Heating the coating to reduce viscosity might affect the flow out of the coating.
It's a good idea to have your finish and your piece to be sprayed all close to the same temperature. You don't want to create solvent pops.
12/28/20       #6: Improving CV with heat?? ...
Bill  Member
Website: canadianacabinets.com
We have set up a 12x12 enclosed area with 4 sun spot infrared heaters and air circulation. Room does not get very hot but the finish is cured in short order. Full racks of painted parts.
    • Supergrit Abrasives
