Subject: Re: "Fastedge" edge banding question
1/8/21
Phill Member
Hi ,
I recently came across Fastedge edgebanding by Fastcap. It's basically a peel and stick edge banding with an adhesive that's pressure activated when you roll it.
I have a small top so typically I just do edge banding with an iron... I don't have a edgebanding machine.
Does anyone have experiece with Fastedge and if so, does it hold up as well as the hot melt tape long term? Thanks!
1/9/21       #2: "Fastedge" edge banding q ...
Mark B
We've used the tape and fast edge occasionally in a pinch and I mainly keep the tape on the shelf for other double stick tape needs. Its no comparison to iron on and iron on is no comparison to bander. If you can get your banding in hot air or iron on I would go that route. Order the smallest amount of fastedge you can get and test it. You cab get your fingernail under it and just strip it off.
1/9/21       #3: "Fastedge" edge banding q ...
Phill Member
Got it, thanks for the response .
