Subject: Re: MDF Door Finishing Final Coat
1/18/21
Rob Member
New to door building. I am building doors for my laundry using MDF. Shaker Style. I have Benjamin Moor Advance Semi Gloss. Can anyone suggest what I might be missing in my steps?
Zen Shellac Primer
Sand
Zen Shellac Primer
Coat of BM Advance
Sand
Coat of BM Advance
I have been told that this paint will be very hard and help reduce door damage over time. Do I need a final clearcoat over the BM or am I good with these steps?
1/20/21       #2: MDF Door Finishing Final Coat ...
Kris Member
i think that should be fine for a laundry room.
I've been happy with Advance in the past.
make sure that you get the mdf sealed very well and don't sand through before you start on the advance though, and be sure to give it plenty of drying time.
1/20/21       #3: MDF Door Finishing Final Coat ...
Rob Member
Thanks. I am using the BIN shellac primer. I am also looking at precat lacquers. Any suggestions on them? I am having trouble finding something that I can color match to a BM color. Very confusing as they seem good but hard to find/decide what to use. I like the fast dry times as I have too many doors to wait hours and hours.
1/21/21       #4: MDF Door Finishing Final Coat ...
Kris Member
If you start getting into bathroom vanities or kitchens where there will be more wear, I would recommend looking into conversion varnishes over precat lacquer.
If you are able to spray solvent finishes, I precat doesn't have the durability in my opinion, so I stopped bothering with it and now don't have to stress about finish failures on anything anymore.
I wouldn't spray without a booth though, precat or conversion varnish.
as for colour matching, that will depend much more on your local suppliers than a brand.
You may have to shop around a bit before you find someone who can correctly tint them up for you, but a good colour matcher should be able to give you consistent matches batch to batch, and hit a colour match relatively quickly.
It's not like Home Depot though, my suppliers ask for 48 hours to do a match.
1/25/21       #5: MDF Door Finishing Final Coat ...
Rob Member
Thanks for the info. The Advance dry time is the main issue for me and why precat was something I was looking into. Would you say they are roughly the same(advance c precat) with the only difference being dry time and solvent based?
2/6/21       #6: MDF Door Finishing Final Coat ...
John Member
Target Coatings will color match any BM color with their EM-6500 pigmented lacquer.
I switched from BM Advance to Sherwin Williams Emerald Urethane Trim Enamel when considering paint. It sprays really easily and dries/cures much faster than Advance. Recoat in 4 hours.
John
