Subject: Re: glass beads in spray canister
1/30/21
mstrasburger Member
This has probably been mentioned here in the past. One time I added a handful of glass beads about the size of Hershey's Kisses to my bottom-mounted HVLP one-quart spray cup because the siphon tube was leaving about a half inch of finish unused at the bottom. The beads went up about 3/4" and worked great, meaning that when my spray feed stopped, the cup was almost completely empty.
I ended up keeping the beads in permanently. They even have another advantage: They make it super easy to agitate the finish in the cup if it has been setting by shaking side to side. This keeps the air pressure inlet into the cup from getting clogged.
1/31/21       #2: glass beads in spray canister ...
Neat.
2/1/21       #3: glass beads in spray canister ...
Jim Clark
I use to use marbles just to keep it mixed real good.
But I switched to a HVLP top load cup and
will never go back to a bottom one.
It's worth the investment and clean up is
so much easier.
