Subject: Re: Medium volume lineal spray finishing
2/15/21
David Waldmann Member
Website: vermonthardwoods.com
We are a relatively small picture frame moulding manufacturer/distributor. We have a series of catalog mouldings that are milled and stocked raw, then finished to order. We also offer custom profiles/finishes, which would be milled to order, then finished.
We have 42 stock profiles, and 47 different wood/finish combinations. So we are often finishing 5-10-20 feet of a particular item.
However, we also have several items that are popular, and we may end up finishing 25-50 feet of those every day, or get individual orders for 100-200-500-1000 LF. We have also gotten quote requests for 1000-5000 feet that we just cannot be competitive on.
We are considering making the jump to an automated lineal spray system, so we can run several hundred feet at a time of the popular items, as well as these larger individual/custom jobs.
However, it's more than a "jump" - more like an Evil Knievel attempt across the Grand Canyon. The machine we're looking most seriously at is a Cefla PSP-6, and like most machines of that type it's capable of 100-150 LF per minute, or orders of magnitude more than we can do by hand.
Between the spray machine itself, air make-up, pumps and guns, the cost to partition off the space, drying racks and things I don't don't know plus those things I don't know I don't know, we are looking at at least $100k, probably $125k.
Pretty big leap. Am I missing a step-stone?
2/15/21       #2: Medium volume lineal spray finishin ...
herb johnson
i am not sure of your widths and i don't know your drying profile, nor your color changes per day etc, but have you looked at an MM150 in the 25-30k range
good luck
herb j
2/15/21       #3: Medium volume lineal spray finishin ...
Chris
I have an older version of a MM150. We use it for spraying dye stain on frame moldings.
It works ok but changing between colors is a pain. Also if spraying sealer or topcoat it gets messy
2/16/21       #4: Medium volume lineal spray finishin ...
Our profiles are mostly in the 1-2" wide range. I wouldn't envision doing more than one or two fluid changes per day. Our typical dry time ranges from 30 minutes to 2 hours depending on coating (all water-based), temp and humidity.
Thanks,
David
2/16/21       #5: Medium volume lineal spray finishin ...
rescraft
Just Googling, one for sale that says it's almost new $81k. I'm sure there are other deals out there. Good luck.
2/16/21       #6: Medium volume lineal spray finishin ...
herb johnson
honestly i am far from an expert in automated finished of mouldings etc i just responded to the question of is their anything else out there, based on what you said, their is a step in the middle , an mm150 type machine, there are a lot of machine mfg's that make this type of machine, it is quite basic with three or four heads, one or two, have seen three fluid circuits, a whisker or limit trigger switch to actuate the guns, you place the machine infront of a spray booth, it is a work horse. i would suggest you investigate to see if meets your needs, it wouldn't make sense to run it for 15ft, etc but it might fit your needs, there are videos of this "type " of machine on you tube. as far as drying the part, you could get a prime heat oven which will do a great job on curing w/b coatings and will be well under the threshold ur were budgeting for the cefla machine
good luck
herb j
2/16/21       #7: Medium volume lineal spray finishin ...
We can't set it in front of our spray booth, there just isn't room.
However I do see that the MM150 machine is available with a hood and fan, and only requires a 120v 1Ph power source, which would be an advantage.
I am waiting for a quote from another supplier for this type of machine. I am, however, concerned with another posters' comment that "...changing between colors is a pain. Also if spraying sealer or topcoat it gets messy".
2/16/21       #8: Medium volume lineal spray finishin ...
herb johnson
if you get a machine with air assisted airless that is your best bet, don't get a machine with hvlp it will be a nightmare.
also get acrastrip for your colorchanges
2/16/21       #9: Medium volume lineal spray finishin ...
Chris
We originally had our machine set up. With AAA but couldn’t get it to work right for spraying dye stain so we switched to hvlp.
Spraying water base would probably work a lot better
2/16/21       #10: Medium volume lineal spray finishin ...
herb johnson
with dye stain the iwata gun with the tulip nozzle is killer set up , so a two circuit machine is the way to go, one diagphram pump system with t;he iwata guns with the tulip nozzles and the an aa system with 15 or 20-1 set up with say a 1 gpm delivery and you will have terrific set up
2/19/21       #11: Medium volume lineal spray finishin ...
JeffA
In my opinion you need to keep all the staining by hand and do the clear coating on the automated sprayer. And it's more important how many different widths of product you have as the automated sprayer is dictated by that. 3 guns on it should be more than good enough if the largest width is only 2 inches.
I wouldn't even think of doing any staining on the machine unless it's a pigmented product and you run 1000's of linear feet at a time. 47 colors are just way too many for an automated line unless you learn to stock finished product which now a days owners hate to do. ;.)
