Subject: Re: Polyester ghosting
Polyester ghosting
3/31/21
Craig Member
I'm following the tech sheet for a polyester top coat.. requires 30 mins between coats. I get serious ghosting when I wet sand and polish.. what I'm doing now is reduced the amount of accelerator from 4 to 3%, and I'm only giving it 5 mins between applications, my coats are light and just enough to saturate the surface. I'm spraying vertical and I can see each coat flow into the previous. Not just sit on top like before.
I think all the applications are amalgamating into one solid coat and I avoid the ghosting.
No sign of any trapped bubbles either, I'm thinning the product slightly too.
Anyways is this a bad way to go with this finish?
4/23/21       #3: Polyester ghosting ...
masterblaster
4% is pretty hot, 2% the norm. you may not have the window you think you have to recoat. I recoat as soon as it dulls down some.
5/1/21       #4: Polyester ghosting ...
Craig Member
Yes, I'm having way better results running 2%. It's basically one thick coating from top to bottom now. No further issues thankfully
