Subject: Re: Spray stain full sheets
3/31/21
MarkB Member
We have to spray stain about 150 full 4x8 sheets. Wondering if any of you have any processes that speed up the application/wiping? We cut dollies on the CNC with very small forks that hold 10 sheets per dollie by the bottom edge spaced one inch apart and not touching each other. Just holds the sheets in the forks by 1/8" of the bottom edge (which will be cut off next op on the CNC) while they flash off. Trying to come up with the fastest/cleanest way to blast these and rag them off barring 2, 3, 4 people and a 55 gallon drum of rags. This is a heavy bodied semi-transparent stain that will never go on without having to be rag'd off.
Im guessing manpower is the only real option but hoped someone would have a trick up their sleeve.
4/1/21       #2: Spray stain full sheets ...
rich c
My personal favorite way to mass apply stain is with a large paint pad applicator. The foam below the pad holds a ton of stain and the pad moves it around well as it pushes it into the grain.
4/2/21       #3: Spray stain full sheets ...
MarkB Member
Thanks a bunch Rich. We had tried a couple of large stand-up foam and sponge pad applicators for both application and trying to wipe/pad down the sheets after spraying but none worked out as well as we'd hoped. Best speedy solution to this point has been one of those pad heads wrapped heavily with rags and chasing the spray application followed by any quick cleanup by hand. This is an odd one (not our spec. but matching a customers existing sheets).
4/5/21       #4: Spray stain full sheets ...
Charles
Consider using a NGR stain.
4/5/21       #5: Spray stain full sheets ...
Matt
Roll it on with those 18" paint rollers on a pole. Pan of stain on the floor next to you. Let the next guy rag it off using bar tender cloths, which are much more absorbant and tough than t-shirts. Cheap on Amazon.
Just discard the stain roller nap carefully because it will be a self-combustion hazard assuming this is an oil/alkyd stain.
4/9/21       #6: Spray stain full sheets ...
MarkB Member
Thanks Matt,
Its waterbourne. We tried the pad/roller but seemed to be able to control the application far better with a .011 on the airless and minimize ragging with terry cloth rags. At least that way the rags dont wind up with more stain in them than the panels do.
I was hoping for a miracle but other than some elaborate feed through finishing line theres no better option than elbow grease.
