Subject: Re: Using lacquer tint as stain
5/1/21
Craig Member
I have a whole bunch of lacquer tints on the shelf as I've moved away from lacquer and now use polyester, the polyester doesn't like being tinted. But I really like the vibrant colours I get with the lacquer tint direct to wood, more so than the dyes I use which are the usual dull kinda vibe... what issues could I run into with this idea? I usually seal stains and dyes with a polyeurthane wash before applying polyester.
Should I??!
5/1/21       #2: Using lacquer tint as stain ...
Bob Niemeyer  Member
Website: niemeyerproducts.com
Depending on the Isolante you use many will allow urethane compatible tints to a certain percentage. What brand PE are you using as I may be able to guide you to the right colorants to use.
5/2/21       #3: Using lacquer tint as stain ...
Craig Member
Hi. I'm using ICA polyester. I have tinted the ica polyurethane isolant to achieve slight fades/shades but they say I should only add a drop or two to the mix or else I may disrupt the chemical make-up.
When trying to tint the polyester it just goes a weird colour after a few minutes.
Any info welcome.
