Subject: Re: Material for edgetape
5/19/21
Ok I am building new doors for an old kitchen, old kitchen has maple doors with a light brown/tan stain. Edge tape on front of cabinet boxes is some awful light coloured oak pvc type. The melamine is white.
I generally don’t do this kind of work, I do just about all new projects, some kitchens, but mostly commercial.
Is there a product that someone can recommend to spray/brush over the existing edge tape that will adhere well and last a long time. Or the alternative is to pull off the old edging and put on new.
I generally hate edge banding manually .
I tried to avoid the job, but since it is a close contact I was told I am doing it. &#128563;
5/19/21       #2: Material for edgetape ...
MarkB
No.
5/19/21       #3: Material for edgetape ...
MarkB,
Lol, That is exactly what I said as well, but my wife said yes.
I think I will give it a quick scuff and then use some of that melamine paint.
5/20/21       #4: Material for edgetape ...
mastercabman
I've done it in the past
I used a white vinyl primer and then top coated
Of course I scuffed sand
That was almost 4 years ago and I will be stopping by that job later today or tomorrow to look at some more work to do
I will check how it hold up
5/20/21       #5: Material for edgetape ...
TonyF
Scott:
I hate this kind of work, but when, for whatever reason, it was necessary to do so, I used this product.
A Virutex double-edge trimmer will make short work of trimming, leaving only the corners to file.
It is something of a short-cut, and it doesn't make for the highest quality project, but then given your approach, it doesn't sound like that is what you are looking for anyway.
Good luck.
TonyF
Just what you need
