Subject: Re: Maybe a dumb question?
5/24/21
mastercabman
So what exactly is the difference between pre-cat and post-cat?
Now I know the definition but is the catalyst the same? Same amount?
Post-cat usually has a 8 hours/24 hours pot life after catalyze(depending on brand/product)
But pre-cat has 60 days to 6 months depending on brand(or even longer?)
Is there a difference in those catalyst?
5/24/21       #2: Maybe a dumb question? ...
Catalyst is much stronger in a post cat. Post cats are usually much more durable and more resistant to abuse and chemicals.
One hour after a post cat dries/cures you can wipe it down with thinner with little to no damage. Try that with a precat and it'll clean the finish off the part.
Precats come to you catalyzed, post cats you do it yourself in small batches or have special equipment that mixes it as you spray.
5/25/21       #3: Maybe a dumb question? ...
rich c
Precats have a self life in the container.
5/25/21       #4: Maybe a dumb question? ...
mastercabman
Thanks Leo and Rich
But I do know what pre cat and post cat definition
But what I'm asking is what's the difference in the catalyst between the two?
Like Leo said that the post cat uses a stronger catalyst
So how much difference is there?
Is it the same catalyst they use for both?
Maybe with less in pre cat?
5/26/21       #5: Maybe a dumb question? ...
MHorrillo Member
Website: http://properwoodfinishing.com
All "Cat" finish's have a "crosslinking" acid that causes "Crosspolymerization" in the resin structure. Most pre-cats have a large percentage of Nitrocellulose as their resin structure. Will add several plasticizers to add flexibility to the material. As an antique restorer , I love nitrocellulose, but it is a solvent release finish and is much to brittle for kitchen cabinets. Ask your supplier if they know what the resin is in your post Cat. Some are acrylic. SW use to make an awesome lab grade cat. vinyl. Conversion Varnish is also post cat. with an aliphatic resin structure.
5/27/21       #6: Maybe a dumb question? ...
Pete Anderson
Website: http:/petesfloors.wordpress.com
Post cat finish like conversion varnish can be refrigerated to prolong the life of the catalyzed finish. It takes a long time to harden below 32 degrees F, but when warmed up in a hot water bath it will work again.
