Subject: Re: Rubbed out lacquer finish
5/27/21
Chem Member
Is anyone still shooting nitro 550 voc, and is anyone rubbing it out. I have a lot of questions: How many coats are you shooting to get thick enough to buff? Do you ever experience the finish cracking because it is too thick? If what you are finishing is an off-white, do you keep building the color coat (off white lacquer), or do you build it with clear on top?
5/30/21       #3: Rubbed out lacquer finish ...
Bob Niemeyer  Member
Nitro is still alive in many industries. Many of the very high end furniture companies and musical instrument manufacturers still use it.
We refinish very hi end furniture and antiques. It is the type of furnishings you do not slap a couple coats of precat,CV or waterbase on.
We have our Nitro custom made for us. We worked over a year with the manufacturer to get the formula just right.
Perfect flow out, can be used in hi millage applications and rubbs out real nice. So no cracking in thick applications.
When doing colors or whites and pastels that is when you have to change it up some,
I will use NC primer or PU primer. Do my color coat and then my polish or rubb coats are clear on top of color. These formulations are very hi in CAB resins to minimize color shift and yellowing of the color. For rubbing or buffing I like a good 4 mill DFT on my base color coat. A skilled person can work with that amount of DFT and get the job done.
6/1/21       #4: Rubbed out lacquer finish ...
MHorrillo Member
Website: http://properwoodfinishing.com
Chemcraft makes a very good nitro. We will use it on 1910-1930 furniture and architectural work for authenticity. Since it is a solvent release finish, it is not mil thickness intolerant as some cat. finishes are. For a piano rub out finish I will use no less that 7-10 (sand between coats) on top of my sealer. Nitro rubs out wonderfully since it is so hard it is almost brittle. I do not start the rub out for a month after my last coat is applied. Remember that most pre-cats are about 80% nitro. For durability Conversion varnishes are more durable and rub out almost as well. My rub out includes: 400-600 wet dry, 800 to 1200. I use pneumatic sanders. Buffing pad: light rubbing compound to glazing compounds. 3M or Maguire's. WB also rubs out well after it id fully crosslinked.
