Subject: Re: Question? Waterbase Toners
6/14/21
Jim Knowles
I am looking to see if anyone is using waterbase color to tone on top of existing lacquer finishes.
Currently I make a toner with 844's, vinyl sealer and lacquer thinner. I am happy with the results. Just wondering about what I will do if they are outlawed? I like them because they bite into the existing solvent lacquer finish with good adheasion. Where as water base just sits on top (even when sanded) of the solvent finish! I never strip the old finish or tone onto raw wood.
So is there a clever meathod to marry waterbase toners with pre-existing solvent base??
just jim
6/14/21       #2: Question? Waterbase Toners ...
What do you mean by “marry”. The adhesion of wb to most surfaces is better than solvent.
6/18/21       #3: Question? Waterbase Toners ...
Jim Knowles
Adam , this is just the information I am looking for! So you are spraying a waterbase toner onto a preexisting cabinet with either solvent lacquer and conversion varnish and have good adheasion success??
Looking forward to learning from you!!
just jim
