Subject: Re: Build-up on AAA Piston
7/10/21
Eric
I got a AAA a little while back and I noticed this build-up on the piston. Is this normal to have this build-up? Spraying CV.
Thanks!
View higher quality, full size image (4096 X 3072)
7/11/21       #2: Build-up on AAA Piston ...
CraigM
No, that's not normal. You probably need a new throat seal or you could have a scratch on your piston. You also look low on throat seal lube, the cup should be close to full.
7/12/21       #3: Build-up on AAA Piston ...
JoeW Member
I agree with Craig.
I have found that that buildup will occur if you do not keep the cup clean and full with clean oil. I reduced the need to change to lube as often, by moving the pump away from the spray area and placing a barrier between it and the spray area.
7/13/21       #4: Build-up on AAA Piston ...
Eric
Thanks guys for the response. I will clean off the piston and make sure the oil level stays higher. I will also make sure there is no overspray going into the cup. If it happens again i'll assume its probably a bad seal or scratch in the piston.
7/13/21       #5: Build-up on AAA Piston ...
mastercabman
When using my pump
I put a clear large plastic bag over it
So that no over spray/dust gets on it
7/14/21       #6: Build-up on AAA Piston ...
JaySun
You can purchase a cover that snaps on to cover all sides of the cup and rod. Helps a lot to keep overspray out.
