Subject: Re: Flatline Conversion Varnish viscosity question
7/15/21
matt
We are likely to be adding a flatline (reciprocating, non-reclaim) for spraying, and we'll probably stick to conversion varnish.
One of the issues we encounter when spraying CV by hand (with AAA pumps) is that various colors are varying viscosities. We spray a lot of KemVar Plus, and have noticed that dark blues/grays frequently are a lot lower viscosity than whites, and it's because the tinters have to add a lot of blending-clear to the mix. That blending-clear is fairly low viscosity.
So we have to thin the blues a lot less than the whites (and, we spray a lot of blues right now).
So on a flatline...... how do you compensate for this? Do you do the same thing (just thin them less)? Do you increase fluid pressure?
Do you measure viscosity using a flowcup before priming up your lines?
7/16/21       #2: Flatline Conversion Varnish viscosi ...
masterblaster
darker colors are a different base. may be straight clear or a mix of clear and color. that's why they don'y hide as well. keep records of your mixes with those colors.
