Subject: Re: exterior table top finish-brushable
8/27/21
Nancy
I'm not used to brushing, I spray. But need to brush a finish on tables that will be outside. What should I use?
8/27/21       #2: exterior table top finish-brushable ...
how much maintenance are you willing to endure?
8/28/21       #3: exterior table top finish-brushable ...
Roy Cameron
Epifanes. Roll and tip it.
8/29/21       #4: exterior table top finish-brushable ...
nicko
Target Coatings has some spray finishes that can be brushed. Or Hellmsman polyurethane by Min Wax
nicko
8/29/21       #5: exterior table top finish-brushable ...
Helmsman is a terrible product. It’s fake spar varnish. All of Minwax products are cheap homeowner.
If you want annual maintenance coats use a marine spar varnish like Epifanes or Interlux. They have the highest ratio of UV protection
The rest of the typical finishes are penetrating solvent based.
8/30/21       #6: exterior table top finish-brushable ...
Jim
Do you prefer the 2k or the single component in the brands you mentioned ?
I have been told that the single component is easier to maintain if you just scuff sand and recoat every year?
With your experience I would greatly appreciate your advice!
just jim
8/30/21       #7: exterior table top finish-brushable ...
2K UV resistant varnishes are not commonly used. The ones I'm familiar with are used for durability. They are tougher and typically put on thicker. We've used them on the yachts for high wear areas.
It doesn't really increase the UV protection. The first layers of varnish get trashed so you need to recoat every year whether is 1k or 2k.
8/30/21       #8: exterior table top finish-brushable ...
Jim
Thank you for your great advice! A much less painful path to success...!
j
10/10/21       #9: exterior table top finish-brushable ...
Nick
Regardless of what finish l'm using for exterior restaurant tables l always start with a coat of clear epoxy sealer this should extend the life of your finish for both spar varnish and 2k poly.× 2 times
BTW; Helmsman is not a bad product...3 coats on the cpes will last for years. Just inspect it every couple of years and reapply before failing...I know easier said then done.
