Subject: Re: What size of tip for laying down Polarion
8/29/21
Thomas77 Member
Hey, curious about your set up for spraying Polarion 2K...what size of needle are you using and type of gun ? Reducing much ?
8/29/21       #2: What size of tip for laying down Po ...
Depends on what I'm finishing. Usually I only use it for countertops.
If I have a large countertop maybe 25"x8' or bigger I use a 12-174 (.015"x70º) at 40psi liquid and 22 psi air. Up to 10% thinning (PS3)
If I'm doing something smaller I use a 06-114 (.011"x50º).
For the most part I always thin up to 10% for flat surfaces such as Maple.
But I've learned that you can thin Polarion as much as you want without degradation of the finish. When I want to do a full fill in Oak I go with 30% (PS3) so it flows better and I can get a full fill in 4 coats with a heavy sand to flatten the coats. Doesn't include the sealer witch is put on thin.
8/30/21       #3: What size of tip for laying down Po ...
Thomas77 Member
Thanks Leo, but I was hoping to hear something like 1.8 ...I'm using hvlp gun..
8/30/21       #4: What size of tip for laying down Po ...
Thin it 30% to start and see how it comes out of the gun unless you have a flow cup that you use.
10/10/21       #5: What size of tip for laying down Po ...
Nick
I've found Polarion to be one of the easiest, trouble free finishes that l've ever used. I'm usually spraying Polarion on Walnut burl sinks that a local woodturner makes; for that l use a gravity gun with a 1.4 needle/nozzle.
But l also spray it restaurant tables and recently on the local college's locker room benches with it for that l use a AAA set-up with Graco 411 tip / Binks 1108.
