Subject: Re: wood finishing
wood finishing
9/23/21
Nancy
I'm having pitting problems. I'm spraying clear conversion varnish on birdseye maple. This has never happened before.
9/24/21       #2: wood finishing ...
Chemmy  Member
Nancy, can you post a pic or two so I can see what the problem looks like please?
12/11/21       #4: wood finishing ...
rick morehou Member
Nancy,
there are many types of pitting with various causes, therefore we will assume the Maple is thoroughly dry so the causes check list starts at the basic and goes on to a basic diagnosis type of trouble shooting to more complex areas.
what was the last that touched the wood?
your environment, temp of material, wood, air. these need to all be pretty close which means they need time to reach the ambient temp that can take hours or more. equally the humidity needs to be stable.
for a tried and true method for removing the pitted CVis to use a card scraper to shave off the surface to wood sand with 180 and dont wipe it with anything, tack it with a cloth used in body shops that is safe for waterborne finishes. then apply a 1or 1.5 pound cut of blonde shellac using a premium denatured alcohol, SW makes a clean DNA and the enviro friendly maker has one. you don't want any waxes or inferior alcohol in it, now it is time to shoot a light seal coat on and carefully watch it as it dries quickly in a few minutes it is dry, sealed hopefully no crap on the surface if so hit it with some 320grt. until good and lay on a light coat let dry and surface with 320 tack it off
and shoot your CV. shellac works. good luck
