Subject: Re: table top
table top
9/23/21
Nancy
How can I get a high gloss sheen from a machine buffing down to a satin sheen?
9/23/21       #2: table top ...
Wet sand with 1000 grit.
9/24/21       #3: table top ...
Chemmy  Member
Nancy, how low of a sheen is needed?
Depending on how low it is you may have to sand and recoat to get it where you or your client will be happy with it...
9/24/21       #4: table top ...
Jim Clark Member
Abralon foam disks by Mirka work great.
You can get them in 2000,3000 & 4000 grit.
Wet or dry.
9/24/21       #5: table top ...
0000 steel wool
9/26/21       #6: table top ...
Thomas77 Member
It all depends on how smooth is the existing finish. Wet sand flat with 600 or 1000 sandpaper and follow with #0000 steel wool, already mentioned here.
Rubbing out finish
